Iron Content in Nitric Acid: Useful Testing Reference
Summary for iron content in nitric acid Discussion
Testing iron content in nitric/hydrofluoric acid is discussed only briefly in the excerpt, but the question is clear: Paul Stone asks how the iron content of nitric and/or hydrofluoric acid is monitored and whether there is a step-by-step test method or reference source. The visible answer begins by citing Langford and Parker, suggesting a reference to a published source or supplier, but the excerpt cuts off before any actual procedure is given. Because the thread text provided is incomplete, no specific analytical method, web page, or journal article can be confirmed from the source shown. The safest takeaway is that the discussion points readers toward external technical references rather than presenting a full in-thread testing protocol.
Q. I was wondering if anyone knew the process by which the iron-content of nitric and/or hydrofluoric acid is actually monitored. In other words, is there a step-by-step process of the actual testing methods to discern the content? Is there a pertinent web-page or journal?
Paul Stone
– Kingsville, Ontario, Canada
A. Langford and Parker, [on
AbeBooks or
Amazon affil links]
, a standard text for analysis of electroplating solutions, says that it is unlikely that the metals be required to be analyzed in this kind of dip. Are you having trouble with the solution?
tom pullizzi monitor
tom pullizi signature
