Cleaning up copper sulphate residue
We use copper sulphate this on eBay or Amazon [affil links] in a simple continuity tester. Since copper sulphate is conductive we use it to test continuity of 20-36 ga. magnet wire without having to burn the insulation off. Is copper sulphate corrosive to paint or metals? When copper sulphate if left to dry, it leaves a corrosive looking residue. Do you recommend any type of cleaning agent to completely remove this buildup?
Chris Follis
A.O.Smith - Ripley, TN
Just not a good idea to leave salts around any metal. A copper sulphate solution will corrode many metal surfaces, since it has some water of hydration, and will probably absorb more from the atmosphere. It is slightly acid.
