Gold plating on stainless steel to pass nitric acid test
I have a stainless steel tube (#304) with a OD of .021 and an ID of .015. I would like to gold plate the inside and outside of this tube with a 10 to 20 mil gold layer without a base nickel layer. The nickel used in the past will not hold up to an 40 second submersion in nitric acid that I need to pass. Any suggestions?
- Kansas City, Kansas
Have you tried using an acid gold strike?
Neil BellAlbuquerque, New Mexico
Is your gold suffering from porosity? Try a mild steel panel and test with a ferricyanide / sodium chloride solution for porosity. This could by why the nitric is eating the nickel.
Martin Trigg-Hogarth
surface treatment shop - Stroud, Glos, England
Have you tried using an electroless nickel process with a high phosphorous content. These processes can withstand nitric acid better than nickel on its own.
Sharon Banner- England
As recommended before a Hi-Phosphorous coating is a good resolution, The amount of gold you require is significant, if I am reading correctly, shouldn't the gold be enough? Anyway there are more than one solution, duplex coatings, etc
Richard Webb- Toccoa, Georgia
We are trying to accomplish a similar requirement, plating the exterior of a .043 OD 304 stainless steel tube. It will be used as a short term implanted medical device. Have you found a solution? Nickel is not desirable due to it's poor compatibility with the body.
Thomas Youd- SLC, Utah
