Will Borax kill wasps and termites?
20 Mule Team Borax
borax_20muleteam
Q. I got to your site by searching, "Borax, uses of." I am looking for something to kill wasps, and since I have effectively used a Borax, sugar, and water solution to kill ants, I was wondering if it would work in a similar way on wasps. They're driving me crazy and I can't find their nest to exterminate them with insecticide. Do you think it's worth a try?
Nancy Kehler
- BC, Canada
A. The 'ol borax in sugar water trick will also wreak havoc on the yellow jacket wasp populations. There are easier ways to kill these critters without endangering useful creatures like moths, birds, etc. If you set out some regular 20-oz PET soda bottles out with a bait consisting of some apple juice & maybe a bit of raw meat with a bit of dishwashing detergent inside, you will catch lots of wasps and flies. Occasionally dump out the contents and refill.
Dale Woika
- Bellefonte, Pennsylvania
Q. My daughter is a first-time homeowner of an older home in New Orleans. Her father and I suggested she put Borax this on eBay or Amazon [affil links] under the house around the foundation to prevent roaches and fleas. This has apparently worked as she has, after a year, seen neither in her home.
We were wondering if we could expect this application to prevent termites? And is there a better way to apply Borax to get results in preventing termites than just putting it under the house? We wondered about putting it in the attic. At the present time there are no signs of termites, and we wondered if Borax might help keep it that way.
Jerri Myers
parent - Lakeland, Florida
A. Hi. Termites require moisture. Although most attics are hot and dry and will not have termites, her neighborhood & conditions might be different so I can't say it's wasted effort. Some termite extermination companies (including the one servicing my house) use baited traps around the periphery of the house, but these traps extend into the damp soil about a foot. You might research what bait they use and what the theory is.
