Process list for EN over 6061 aluminum
Customer looking to setup EN over 6061 aluminum , I need a process list. Has existing cleaner / rinse/acid/rinse I can use.....
Ron Landrette
plating equipment supplier - Bristol, Connecticut
The plating line you will need is a Soak cleaner, etch, desmut, zincate, zincate strip, zincate and then plate. Also you should have a few rinses in between each step.
George Shahin
George Shahin
Atotech - Rock Hill, South Carolina
