HARD GOLD PLATING
I AM A MANUFACTURER OF 22CT, 21CT 20CT AND 18CT GOLD ORNAMENTS. IN THE CASE OF 22CT GOLD ORNAMENTS WHICH IS 90% OF MY PRODUCTION THE METAL BEING TOO SOFT , IT LOOSES ITS POLISH GLOSS IF HANDLED A FEW TIMES. AFTER POLISHING THE ORNAMENTS I color THE SAME WITH THE PROCESS OF ELECTROLYSIS, WHICH GIVES IT A VERY DEEP GOLDEN color. THE ELECTROLYSIS BATH IS CYANIDE BASED. BUT THIS PROCESS DOES NOT GIVE A HARD COATING TO THE ORNAMENTS WHICH CAN BECOME SCRATCH FREE TO A CERTAIN EXTANT.
KINDLY ADVICE ME WHICH PLATING PROCESS SHOULD I USE. WILL THE USE OF HARD ACID GOLD SOLUTION BE USEFUL.
- Mumbai, India
Gold electrodeposited for a low pH "acid gold" bath will produce a harder surface, especially if it contains some cobalt. These baths can produce a very nice 24K gold color and you should ask your supplier about them.
Neil BellAlbuquerque, New Mexico
