Soldering Stainless to Brass
We are trying to bond Stainless Steel tubing to a brass manifold in an application that cannot tolerate corrosion. I've heard that a coating of copper or tin can be applied to the stainless to increase solderability without resorting to an acid core flux. We just need to coat the outside of a thin wall, 3/8 in. o.d. tube for about an inch on each end.
Can this be done at reasonable cost compared to the price of the tubing? Should I try something else?
Will J [surname deleted for privacy by Editor]
Vanderbilt University - Nashville, Tennessee, USA
Yes, Will, you can copper plate the tubes after you have Wood's Nickel plated them. The familiar Revere Ware copper bottomed stainless steel pots can be used as a model of how it would work. Good luck!
