Spec Zinc Coating ASTM A153
I am trying to find the spec for zinc coating
ASTM A153
, Grade 'C'. My customer is needing this process on .688 hex part.
Appreciate any help.
- Tilton, Illinois
Hello Bonnie!
ASTM A153 , "Standard Specification for Zinc Coating (Hot-Dip) on Iron and Steel Hardware", is available from the American Society for Testing and Materials (www.asminternational.org). This three page specification is found in ASTM Volume 01.06. The website gives more information.There is no "Grade C" listed, but there is a "Class C", referring to coating thickness. Class C calls out 1 ounce per square foot thickness, which translates to about 1.7 mils. The specification further covers the quality of zinc used, the sampling procedure, and test methods.
Lee Gearhart
Hello Bonnie,
I have the same problem. Our customer requires
ASTM A153
and additional
ASTM B117 and
ASTM B487. Did you find anything. For me in Germany it is not easy to get all these American specifications.
Thank you in advance.
- Germany
Ed. note: We've linked these specs to a commercial source from which you can get them, Uwe.
