Home of the world famous 'finishing.com HOTLINE' (since 1989)
Tin/lead whisker & excess solder problem
"Failure Modes and Mechanisms in Electronic packages"
"Electronics Manufacturing with Lead-Free ... Materials"
Q. Hello there, I am a process eng'r doing a tin-lead plating on IC leadframe (Copper alloy base material). I am having a sort of problem (on and off), that is whiskering and excess solder (a lump of solder hanging) when I plate on Olin 7025 C leadframe material (containing some Nickel and Silicon).
Can any body help how to overcome such a problem ? Thanks
hari subronto
A. Dear Hari Subronto,
I know that some base materials have a tendency to form Sn-whiskers when solder plated.
As far as my knowledge goes, this phenomena can be solved by using a copper layer before the Solder plating.
Especially CuZr alloys are sensitive to this problem; I don't know to what extent this also occurs with alloy 7025.
The excessive solder looks like a shielding problem. Do you use reel-to-reel or rack-plating?
In the first case, shielding improvement should be quite easy and this will improve the primary current distribution.
Success and I greatly appreciate it if you will sooner or later tell if you solved the problem and how.
Bye, bye,
Harry van der Zanden
consultant - Tilburg, Netherlands
A. Hari,
On etched products I solved this problem by shutting off the alkaline precleaners (assuming brighteners are in balance). OK on etched, preplated because they go into plating clean. But if you are plating post assembly but pre trim & form, the problem is different since you must deflash, etc. Whiskering at this point strongly indicates brightener imbalance, or brightener breakdown products accumulating in the bath. You must Carbon treat & replenish organics regularly, but realize that some organics are not completely removed and will continue to accumulate until the bath must be dumped. Also, a 60 microinch Nickel deposit is usually required under the Solder. Is it true for your process? This also changes the problem.
Good Luck,
Dave Kinghorn
Dave Kinghorn
Chemical Engineer
SUNNYvale, California
A. Tin whiskers have caused ESA several problems. We have performed many examinations and some growth studies:
"A laboratory study of tin whisker growth" ESA STR-223, 1987
"Mechanical and Electrical Characteristics of Tin Whiskers with special reference to Spacecraft Systems" ESA Jnl vol 11 (1988) pages 1-17 B.D.Dunn
A compilation of various actual whisker problems on many substrates including printed circuit boards is in Chapter 7 "Whisker Growths" of book Metallurgical Assessment of Spacecraft Parts, Materials and Processes[this on Amazon affil links] by B.D.Dunn published by John Wiley & Sons in 1997.
I have never seen whiskers growing on tin-lead surfaces (regardless of substrate material). Incidentally, I keep a dessicator with hardware samples that have grown whiskers. I would very much appreciate receiving any new samples which anyone out there might be willing to send me.
Barrie D. Dunn
European Space Agency, Noordwijk, The Netherlands
A. Hari Tin plate your lead frame then reflow fuse the tin. Whisker growth is the single greatest repeat failure in the electronic industry today.
C Haynoski
- Van Nuys CA
A. Dear Hari,
Pretreatment is the most important process before plating regardless of base materials. Importantly the right chemicals for impurities removal before plating.
sw yen
- Malaysia
A. Perhaps you can try a conformal coating with whisker suppression? See www.hybridplastics.com/specsheet/Short-stop%20Spec.pdf
Joseph Lichtenhan
- Hattiesburg, MS USA
December 15, 2008
Ed. update Dec. 2022: That link is broken.
Q. We are looking for how to simulate whisker problems on tin-lead solder or printed circuit boards. Any photo and procedure are highly appreciated. Thank you.
Carl
Carl Chan
- Hong Kong/China
Q. Dear Harry van der Zanden,
How important is Sn coating for shielding? Does the surface smoothness play a major role there?
John Appa Durai
- Newport News, Virginia
No dead threads!
Your Q, A, or Comment puts this thread on The Finishing.com HOTLINE.
