Wanted to buy aluminum sheet with tin, chrome, ou UV sensitive coating
I would like to buy aluminum sheet hot dip coated with tin or tin alloy solder for soldering in the next production step.
Can you advise if such material is available.
Fredy Ornath
materials systems - Israel
We need Aluminum sheets chrome plated and with thermal grey paint of back for road signs makin.
Majd Abbassi
HSP
I would like to buy Aluminum sheets coated with seneitive material to Ultravilot& exposed by NAOH doubleface,0.5mm thickness, 48 *98 cm2, black. Can you advise if such material is available, and how can I purchase them?
Amira
