Need PolyOND or PolyORD
Looking for a supplier of a material known as Poly OND or Poly ORD.
I believe these are trade names( Not Sure ). It is baked at 700F.It is most likely a type of teflon.
Jim Cummings
powder coating - Buffalo, New York
Jim:
PolyOnd is a trade name for an electroless nickel coating with Teflon. Contact PolyCoatings in Leominster, MA or Sarasota, FL.
Ed Bayha
Metal Coating Process Corporation - Charlotte, North Carolina
The supplier of PolyOND is Poly Plating Inc. in Chicopee, MA. This coating is also available from Poly Coatings of the South located in Sarasota, FL. PolyOND is Electroless Nickel infused with TEFLON.
Tony D'Amato
- Chicopee, Massachusetts
Do tools have to be sent to you or is it a product I buy from you and I do the coating?
Jeff Elliott
- Flippin, Arkansas, USA
