Oxidation of aluminium without electricity
1. Oxidation of aluminium without electricity.
2. Hardcoat additives or methods in speeding up anodizing process.
Thank you, your info is much valued.
Micheal Ho
- Malaysia
I have not heard of anodizing without electricity, Michael. Hardcoat additives allow you to do Type III (or what some people call "Type 2-1/2") anodizing at a higher temperature, approaching room temperature, but I don't think they speed anything up.
Sorry that no readers have joined in. But it's not not because no reader has knowledge of these subjects, so please spend a few paragraphs delimiting your questions and explaining your situation, and I am confident that the readers will be happy to try to help! Good luck.
What is the effect/consequences of 2 pieces of aluminium plate (mill) fastened together when it is subject to normal/harsh weather test. What is the state of the aluminium? Any coating required?
Sng Guan Hwa
Construction - Singapore
Hello, Sng. Aluminum is an active alloy that offers no corrosion resistance. It must be anodized, or chromate conversion coated, or conversion coated and painted / powder coated. Sometimes fastening two pieces together forms a capillary channel that will draw in water or salty water and accelerate the corrosion. Good luck, but you have to finish the aluminum.
