Accelerated humidity test for powder coated magnesium
1996
I NEED INFO ON THE ACCELERATED LIFE TEST TO STUDY GALVANIC CORROSION.
TRADITIONAL "SALT FOG" IS ONE OF THE TESTS. UNFORTUNATELY I CAN NOT USE IT. CAN I FILL THE HUMIDITY TEST CHAMBER (85 °C AT 85% RH) WITH CO2 TO ACCELERATE THE TEST.
OTHER METHODS?
I WILL BE TESTING Mg ALLOY (WITH POWDER COATING) AND COPPER SUBSTRATES. THE PURPOSE IS TO COMPARE THE QUALITY OF THE PROTECTIVE COATINGS.
CAN YOU HELP ME?
THANKS.
Deepak K Pai
