Conductivity of zinc plating with chromate conversion coating
I'm an engineer involved with designing enclosures for electronics. We use EG steel sheet typically between 16 and 20 gauge. I am looking for a industry standard that I can put on my prints to call out EG steel that has an electrically conductive post treatment like trivalent chromate.
I have found ASTM A879 that covers coating weights but need a designator for a conductive conversion coating.
B
- Boston Massachusetts
September 28, 2021
1996
Q. Actually we have a system enclosed in a box made of steel plated with zinc and yellow chromate. After I did some testing I found that the chromate doesn't offer good conductivity. That doesn't make a good shielded box.
If we only apply zinc with no chromate the finish is very conductive but I was told that corrosion could occur rapidly. Is it right ?
I'm looking for a finish or coating that
protect steel from corrosion
could be painted ?
is very conductive
relatively low cost
Could you help me or refer me to a company.
Best Regards
A. Did you try "blue" or "clear" chromate - it is much thinner, therefore more conductive.
You should not be afraid of corrosion - Zinc with or without chromate provides almost the same degree of protection to steel. Without chromate your finish is easily fingermarked though and will show Zinc corrosion (white powder)much sooner than with chromate.
captive metal finisher - Montreal, Québec, Canada
1996
A. Max is right, blue passivation is the correct answer. If blue is still not good enough, try a short dip in 0.5% nitric acid. The nitric does not improve white corrosion resistance but gives a better appearance.
Sara
Sara Michaeli
Tel-Aviv-Yafo, Israel
1996
Q. Hello:
We produce rack mounted audio/video equipment for the broadcast industry. I would like to know which has the best conductivity and to what degree are the differences, between zinc with clear chromate, yellow chromate, and black chromate. Are their any differences in the corrosion resistance of the three. We need the best electrical grounds for EMI.
Don
- Salt lake City, Ut
A. Don,
Because the chromating conversion coatings are very thin, they are all conductive. However, clear chromate film has relatively low electric resistance since it is thinner than yellow and black chromate films. On the other hand, yellow and black chromate coatings offer much better corrosion resistance than clear chromate coating.
Ling
- Grand Rapids, Michigan
A. I agree with the statement in regards to all three chromates being conductive, but is this true for the new wave of Tri Chromates as well?
Abel Salazaranodizing and plating - Anaheim, California, USA
February 28, 2011
Q. Hi;
We are using electrodeposited zinc coating on steel with additional chromate conversion. The process of this plating is performed according to the standard ASTM B633 type II. This standard does not specify if this coating (yellow chromate) is conductive ( electricity point of view). Since this finish will be used for grounding purposes. So I well appreciate to have some help regarding this issue.
Thank you in advance
- Quebec - Canada
A. There are several grades/types of chromate ranging from clear to yellow, to bronze, to Olive Drab. In general, the biggest difference between these grades is the thickness of the chromate conversion coating (although bath recipes and procedures my differ as well); with clear cad being the thinnest and OD being the thickest.
The electrical conductivity varies as well with clear being the most conductive and OD being the least. Yellow cad is a middle of the road plating, offering a compromise between electrical conductivity and longer corrosion resistance.
- Lombard, Illinois
