Experiences with black nickel plating
Lately we have had several requests in our shop for "black nickel". I understand that this can be accomplished in an EN bath during a post plate process, using a common EN strip, or even nitric acid. Anyone have suggestions, experience, with this process? Is the application functional or simply aesthetic? -- Jim
JAMES D MCCARRICK
1996
1996
A black nickel coating is usually accomplished by electro- rather than electroless deposition. The best known bath forms a Zn-Ni deposit that is very thin (1-2 micrometers, if memory serves) and black in color. The protective value of these coatings is minimal, they are mostly used for decorative and functional (solar energy heat exchangers) applications over a protective layer of nickel or nickel-copper.
berl stein berl sig
"PlaterB" Berl Stein
NiCoForm, Inc.
Rochester, New York
nicoform
November 21, 2008
Good point, Berl. Thanks. letter 7077 also talks about black nickel plating.
