Activation of Stainless Steel for plating
1995
Q. Teaching the AESF L.A. Branch this semester, and several students mention problems with plating Alloy 55 (stainless steel) without blisters. They say they use Wood's Nickel Strike after etching, rinsing, etc. But after baking at 375 for 23 hours (per spec), they get blisters, Would using a special copper strike after the Wood's Nickel or in place of it be a possible cure?
Best regards, Myron
L.A. Branch AESF, Los Angeles, California
A. Many years ago I ran a line plating mil-spec cad, watts nickel, and nickel-cadmium. Process was electroclean in a cyanide based deruster/cleaner with a periodic reverse (5 min racks, 10-15 barrels), rinse, HCl pickle (also on periodic reverse),10-15 sec, (leave on reverse cycle) rinse, wood's nickel strike, rinse, then to process (cadmium plating/nickel plating, etc.). Many of these parts went on to baking afterward, without difficulty (that I'm aware of) -- leading me to believe that the surface prep cleaning may be responsible for your blistering
plating equipment supplier - Bristol, Connecticut
by Jack Dini
AbeBooks
A. Hi, folks. I think the best source of good information on Wood's Nickel Strike and adhesion to stainless steels is found in Dini's "Electrodeposition: The Materials Science of Coatings and Substrates", where he gives tested adhesion values for various operating parameters. It's very good at taking us from general rumors to genuine adhesion science. Good luck.
May 17, 2009
