Types of welding
Can you give me definition or description of "gas tungsten arc welding" and "gas metal arc welding". Also, some data about laser beam welding (speed,energy introduced to the welded metal, maximum thickness of metal to be welded).
Hesham Elbanhawy
- Abu Dhabi, UAE
What is meant by soudronic welding.
Dinakar Reddy
- Newcastle, London, United Kingdom
It's the fusion of metals together by the aid of passage of a current which generates heat of high temperature enough for the fusion of metals using a tungsten electrode as a filling material.
Rasha Adel Mohamed Ahmed
student in faculty of engineering - Cairo, Egypt
