Removing the Oil From a US10B Hardware Finish
I have a customer who has existing door hardware with a US10B oil rubbed finish. They are dissatisfied with the uneven way the oil finish wears off where the hardware is touched. Does anyone know a way to safely remove the entire oil finish to expose the bare metal finish beneath?
RHONDA HANSAL
van Dijk Pace Westlake Architects - Cleveland Ohio USA
Oil Rubbed Bronze Hardware
Mineral Spirits
mineral_spirits
If it is a true OIL RUBBED finish you can use any one of the following strippers to remove the oil.
1. acetone ⇦ on eBay or Amazon [affil link] Flammable!
2. Paint Thinner(mineral spirits ⇦ on eBay or Amazon [affil link] )
Do not use any abrasive, this will damage the chemical color finish. Once the oil is removed you can then spray on a clear acrylic lacquer.
Mark Rekdahl
- Los Angeles, California, USA
