Brightener for nickel sulfamate solution
Q. Is there a brightener for high speed nickel sulfamate plating solution? or is there a way to get a brighter deposit by using lower current or something similar?
veronica dewis
- USA
A. In a word, yes. There are several commercial formulations available; check out the vendors on this site.
James Totter
James Totter, CEF
- Tallahassee, Florida
A. Yes. Most bright nickel(sulphate type baths) will brighten the deposit of sulfamate. You do give up some of the physical properties of the sulfamate solution(ductility and stress). Maybe a standard Watts type bright nickel plating bath would be worth considering.
David Grimm
- Ashland, Ohio
adv.   nickel how-to book
"The Sulfamate Nickel How-To Guide"
by David Crotty, PhD
& Robert Probert
published Oct. 2018
$89 plus shipping
