Heat treatment of low carbon steel
Hi,
I'm a student, I need to kwon what is the temperature of solubilization of cementite in a SAE 1005 steel?
Luciana Stuewe
- Joinville, Santa Catarina, Brazil
I'm slightly unsure of what your asking.
If you want to know when cementite forms a solid solution with ferrite, in what is called austenite. Then it's 723 °C.
If you want to know then a liquid plus austenite solution starts to form, then it depends on the carbon content of your steel. Get an iron-iron carbide phase diagram, also known as iron-carbon equilibrium diagram, all good text books should have them. And read off that.
I hope this has helped.
Ian Brooke
university - Glasgow, Scotland
For the steel you have referred lower critical temperature will be the solutionizing temperature for cementite
Biswas D
- Noida, UP, India
