Chemical stripping then solution analysis to determine heavy metals in plating layers
July 22, 2013
Q. I hope you guys can help me with an analytical task.
I need to strip plated layers from substrates to determine the presence and concentration of certain heavy metals. I can only do this chemically. The solution I use should be of analytical grade, so it is unlikely to be a proprietary mix.
Specifically the task requires stripping the following plated layers:
tin from brass substrate
solder from copper substrate
tin from steel
tin from copper
I have ICP-OES available to analyse the solutions.
Matthew
Matthew Macariou
- Cheshire, United Kingdom
