Suitable material for covers for sumps containing caustic and acid
Dear Bob,
I am a structural designer and have to design a structure to cover a sump used for the waste water containing caustic 50% and HCl 50%. it is commonly conceived that we can minimize the effects of evaporating fumes on the structure by using Stainless steel. but I doubt, can you please suggest me some suitable material for the specific use we intend to.
regards,
Imran Thakur
structural designer - Jubail, Saudi Arabia
February 9, 2011
Hi, Imran. If loading permits, I'd avoid metal entirely and use vinyl ester fiberglass. Grating shapes, including covered grating materials, with or without non-slip grit, are widely available and will probably prove superior to metals costing many times more.
If the same sump will alternately contain 50% caustic and 50% HCl you should be wary of highly exothermic reactions. good luck.
February 9, 2011
