Bright Dipping Anodized Aluminum
I am looking for the best way to get a shiny reflective finish on an anodized aluminum part that has been dyed. I have heard of bright dipping but am unfamiliar with the requirements. I am familiar with the health hazards and was wondering if there is an alternative?
Steve adams
- cedar city ut usa
Bright dipping is done before the anodizing and dyeing, it can't be done afterward.I believe there are also soluble waxes and teflon dispersions that can be used in the seal tank to give some extra smoothness. But once a part is dyed and sealed, I know of no way to brighten it.
If you are talking ones or two's, why not wax it with an appropriate wax and buff it on a power buffer?
You can mechanically buff dyed and anodized aluminum, and it can do wonders to the luster of a surface. Use a cloth buff and some brown tripoli buffing compound this on eBay or Amazon [affil links] . Don't use anything heavy duty super speed as far as the buffer goes, I've used a bench grinder with a cloth buff attachment, it works great. Its fast enough to move the material, but not so fast that it would cut the material or damage the finish.
Matthew Stiltner
- Toledo, Ohio
