Home-brew Nickel Stripper?
Hello,
I am looking for a formula for a nickel stripper that I can mix up myself.
I have some delicate parts that can't be replaced and I want to strip the nickel and then use an epoxy primer.
Or
Can you suggest a "Prep Process" that will allow me to paint over the nickel plate and still have good adhesion?
Dave Dowling
Sheetmetal - Paso Robles, California
September 16, 2010
Try next solution: 10 gm ammonium persulphate/5 gm ammonium carbonate/100 ccm ammonia on eBay or Amazon [affil link] (D.o,935).Keep it in dark.Immerse objects in solution in tightly covered jar(loss of ammonia must be kept at minimum!).
According to R.H.Angier:Firearm bluing and browning
