How does bending affect corrosion of a steel nail?
I'm doing an experiment in High School (year 11) on corrosion. I took 8 steel nails (not galvanised) and I am doing different things to each of them to see how this affects their corrosion. I have decided to bend one of the nails 90 degrees. How will this effect the corrosion of the nail, after I place it in water, and why, if, it does affect the corrosion of the nail.
Steven S
student - Brisbane, Queensland, Australia
May 21, 2010
Hi, Steven. Tensile stress makes steel anodic. If the bend is sharp, you should see more corrosion there.
May , 2010
