Yellowish stain on metal cabinets after powder coating
Yellowish stain on metal cabinets after powder coating of color whitish gray...It has been the problem for metal cabinets...It always appears on the side part...It's just like a honey being poured on the pancake.. Can you help me to resolve this problem?thank you...
Donald Rey Dia
quality supervisor - Philippines
November 9, 2009
November 11, 2009
Could be overcuring?
But more details needed to answer this question.
What thickness material?
What type powder?
What pretreatment?
What cure time? temp?
thickness of discolouration?
geoff_crowley
Geoff Crowley
Crithwood Ltd.
Westfield, Scotland, UK
crithwood logo
Kind of sounds like the side of the cabinet is in close proximity to a vent as it is curing, if that is the case maybe you could block it and see if it makes a difference.
Sheldon Taylor
Sheldon Taylor
supply chain electronics
Wake Forest, North Carolina
November 12, 2009
I have had a similar problem in the past, it turned out to be a oiler for the chain that our parts hang on. it always showed up on the larger parts.
Doug Samson
- Greenwood, SC, USA
November 14, 2009
