AMS2468 vs. AMS2469
I am interested in learning why ams2468 was cancelled? My part requirements have ams2468 on the blueprint, however, AMS 2468 is "cancelled" and replaced by the latest version of AMS2469. Are there any significant differences between these specifications? Why the need for this spec to be cancelled? Is it due to an industry standard or a process change?
Jim Pohoryloproject engineer - Middletown, Connecticut
May 27, 2009
June 2, 2009
AMS 2468
was cancelled back in Sept of 1999. My memory's not good enough to remember why we did that, but looking at it and AMS2469 shows that they're both for hard anodize of aluminum. While 2469 included a corrosion test on sealed test panels, 2468 did not. Otherwise they were almost identical.
My guess is that our thinking at the time was "Why have two specs for the same thing? If I get my parts sealed, I'm going to want a corrosion test, so let's cancel the spec that doesn't require that test, and replace it with the one that does." The corrosion test is a periodic test; it's not done every lot. Finally since parts processed to AMS2469 meet and exceed the requirements of AMS 2468
, I doubt we had much discussion on the decision.
Lee Gearhart
Lee,
Can the same approach be maintained for review of few more standards? Such as AMSQQP416 w.r.t. AMS2400Y, AMS2410 w.r.t. AMS2411, etc?
- Bangalore
July 9, 2009
