IAW ASTM B545 Tin plating needed
March 10, 2009
Trying to find someone in the S.E. Michigan area that can tin plate to the following specs:
Tin plate, class Cu/Sn 5,
i.a.w. ASTM B545
That's exactly what is on my print to quote from and so I can't answer if it's a bright or matte finish or does the spec determine that.
The parts are .187" X 1.00" X 7.50" Copper 110
Qty: 4330
Thank you for your time,
Brian Wood
Machinist - Clinton, Michigan, USA
your name here
