Calculate Dispense Volume of Liquid Copper sulphate
September 25, 2008
How do I calculate the amount of liquid copper sulphate this on eBay or Amazon [affil links] to add to an acid copper bath when we originally used flakes? For example, we would add 2 kg of copper sulphate flakes. How do I go to a volume. The supplier told me the density of the copper sulphate is 1.166 but I thought (CuSO4.5H2O) has a density 2.284. Can someone please walk me through the process of eliminating the units to leave just kg?
Michael
Michael Hedrick
Harrisonburg, Virginia
Michael,
You first need to find out what the weight (as copper sulphate) per volume (liter, gallon, etc)is of the liquid copper sulphate you purchased. This is usually on the container, technical data sheet and/or product MSDS. If all else fails, call the manufacturer. When you have this information it's a simple calculation to get the dry weight equivalent.
Gene Packman
- Great Neck, New York
September 26, 2008
