Problem with plating cracking Stainless Steel - help needed
September 16, 2008
I've got a small deep drawn product made from 3/4 hard, 304 Stainless. I need it to be black and the surface needs to be electrically conductive.
Our vendor suggested using a process they refer to as "black nickel strike". Unfortunately when the parts go through the blackening process they crack in the corners where the residual stresses are at their highest.
Can anyone suggest an alternative plating process which will give me a black, conductive surface with no cracks?
Eric Christison
design engineer - Edinburgh, UK
Hi Eric,
Just a thought: if no one comes up with an alternative black and the black nickel meets your other requirements, is it practical to anneal the stainless steel before processing?
Harry
Harry Parkes
- Birmingham, UK
September 21, 2008
About/Contact - Privacy Policy - ©1995-2025 finishing.com, Pine Beach, New Jersey, USA - about "affil links"
