-----Nitric acid test in electroless plating
what are the observations to be considered while nitric acid test on Electroless plating
Harish PV- Bangalore, Karnataka
September 8, 2008
Hi, Harish. That's a pretty broad way to phrase it. Can you please clarify what your particular issue is? Safety in handling? Amount of acid to use? How long to leave in place? How to interpret the results? Give us details and I think you'll get an answer. Thanks!
September 12, 2008
