Thread 494/01
Suggestions for metallic finish polypropylene
Hi, as you are probably aware, parts made from polyproplyene with a metallic finish are notoriously bad for showing flow lines. Can anyone suggest a way of finishing a PP part, that achieves a metallic finish, without increasing the price? Thanks!
Sarah AndrewsDesigner - London, UK
July 21, 2008
publicly reply to Sarah Andrews
Is this a final year project or something!
publicly reply to Trevor Crichton
July 29, 2008
One of the things that makes polypropylene good is that it is relatively inert. This means that it is hard to do anything with it. Metal or paint are both hard to get to have but the most minimal adhesion. You might kill the gloss with a light blast, probably with tiny glass beads at a relatively low pressure. This will tend to hide the flow lines, but it will get dirty quicker and some might think that it is ugly.
Now, at no increase in cost. Absolutely not possible. If you just wash it and dry it , you have used physical resources and time. Both cost money.
Have you looked into an appropriate dye. It might help and it might not. Not all poly absorbs moisture the same.
publicly reply to James Watts
