Dirty Steel prior to Powder Paint Wash
July 8, 2008
I have a problem with my powder paint peeling off in strips of my Cold Rolled Steel within 2 weeks of being painted.
Our process is a
5 stage wash/rinse
Powder Paint (electrostatic)
433 degree oven for curing (Line speed is 15-18 minutes in the oven)
We tend to paint the parts and place them in baskets and store them outside until needed for use in assembly.
I noticed when I pulled the paint off in a large strip that there was rust under the paint.
Can you give me some advice?
Marie Dobbs
Quality - Worcester, Massachusetts
Hi, Marie. The work may be passing through 5 stages of ostensible cleaning and pretreatment, but it's not being cleaned and pretreated :-)
July , 2008
I would really need to know your pretreatment process in detail to give any specific advice. Most of the problems I've run into when I am called to help companies is the lack off "process control". To many times something is out of control such as the chemical concentration percentage, the temperature or impingement. I am sure your chemical supplier can help you with this problem. Bob
bob utech
Bob Utech
Benson, Minnesota
powdercoat_utech2002
Ed. note: Bob is the author of:
"High Performance powder Coating"
on eBay or AbeBooks
or Amazon [affil links]
July 13, 2008
