-----Pinholes in powdercoating
March 4, 2008
Pinholes in powdercoating on galvanized steel seem to be a poorly explained problem. Some claim its gas emerging from the zinc (hence the name sometimes used - gassing), but what gas? and how did it get there?
Some say its due to pretreatment liquids penetrating the zinc
(really?)
Some use a "degassing " procedure, involving heating the steel to curing temp between pretareatment and powder application, cooling again before spraying.
Some use "anti-gassing" powders that skin over slower, allowing the gas to escape.
What do you think? What causes it? Why do some steels exhibit it more than others? Why does galvanneal show it worse that regular hot dip?
Geoff Crowley
Crithwood Ltd.
Westfield, Scotland, UK
April 18, 2008
Dear Mr. Geoff Crowley
here I am giving my experience on degassing problem when we powder coat on different types of steel or same MS steel(crca)of two difference batches.
this degassing problem is connected with the metal composition.
- Gurgaon, Haryana, India
