Phosphating system layout & design
Hello dear sir
I research about plant design & layout of phosphating plant.
for example;i want to control phosphating bath or pickling section ,what way can I select for proper design ? what way can I calculate the water or waste water consumption ? the waste water treatment ? IF you help me ? i......
Thanks. king regard
MASOOD RADPEY
SAADAT_ARAK - TEHRAN,TEHRAN,IRAN
Most pretreatment chemical companies can send you a recommended process, depending on your type of parts, production rate, and a whole lot of other variables. You can also contact Chemical Coaters Association International for several manuals dealing with system design and other finishing related topics. You can e-mail me your specifications and I can try to give you some guidance...
Jeff Watson
Jeff Watson
- Pearland, Texas
Dear sir
I am working in car manufacturing company . I have a question about pretreatment line . If we want to use half dip-half spray system(dip-spray)and we have limited area can we use spray system for activation and passivation stages.
with est regards n.mobasseri
mobasseri nasrin
- Tehran,Iran
