What is the difference between AISI 4130 and the Chinese 30CrMo
I am about to build a vessel of AISI 4130 but finding it very hard to find as I need it to stand 10,000 psi WP. I went to China in search of this and was told that the equivalent is 30CrMo. I contacted the ASME office in China and they said they can't say whether the two materials are equivalent,
Can someone please shed some light on these two materials and what are the differences if any?
Many thanks
Abdullah ismaily
Consumer - Muscat, Oman
A. AISI 4130 and 30CrMo are nearly equivalent in composition. From the Internet:
-  AISI 4130: C 0.28-0.33, Cr 0.8-1.1, Mn 0.4-0.6, Mo 0.15-0.25, P 0.035 max, S 0.04 max, Si 0.15-0.35.
-  30CrMo: C 0.26-0.34, Cr 0.8-1.0, Mn 0.4-0.7, Mo 0.30 max, P 0.035 max, S 0.035 max, Si 0.17-0.37, Cu 0.20 max [compositions in weight %].
For pressure vessels, the heat treatment and quality requirements must also be specified, as by giving an ASTM or ASME specification and grade. 4130 isn't usually used for pressure vessels (except for non-welded gas cylinders). E.g., the C content is too high and the Mo is too low to meet any of the grade requirements in ASTM A387, 'Standard Specification for Pressure Vessel Plates, Alloy Steel, Chromium-Molybdenum.' For deep drawing quality alloy steel as for gas cylinders, one can specify 4130 per ASTM A507, 'Standard Specification for Drawing Alloy Steel, Sheet and Strip, Hot-Rolled and Cold-Rolled.'
Ken Vlach [deceased]
- Goleta, California
What is the difference between 4130 steel and 25CrMo4 ?
Q. What is the difference between 4130 Steel (www.astmsteel.com/product/4130-steel-aisi-25crmo4-7218-scm430/) and 25CrMo4 steel ?
Some say the two steel grades are equivalents but except the chemical composition difference. What's the other kind of difference. Please give as detailed reply as possible.
Jeremy He
product manager - Dongguan city, China
December 10, 2015
Ed. note October 2020: Jeremy's reference is now a broken link :-(
A. Jeremy,
In my big book of alloys (SAE HS-1086/ASTM DS-56K), 25CrMo4 maps to UNS# G41300, while 4130 maps to G41300, J13048, and K13147.
The given composition ranges for those three aren't exactly the same, but they overlap in such a way that one composition could qualify as all three.
ray kremer
Ray Kremer
Stellar Solutions, Inc.
McHenry, Illinois
stellar solutions banner
