How can I cause gold plating to tarnish, or seem "aged"
Hi, I work on some old musical instruments. Occasionally, I need to replace some gold, and would like to know a way, chemically or otherwise, to artificially age the gold ;-)
How can I CAUSE gold plating to quickly tarnish, or seem "aged ?"
James Wagner
- Soulsbyville, California, USA
Oil it very very sparingly (any edible oil or fat),then heat it to 300-400 °C (with hot air gun).Instead oil you can use 2-20% shellac solution.Second option is thiosulphate based patina(dissolve 240 gm sodium thiosulphate on eBay or Amazon [affil links] /25 gm copper acetate [affil links]/30 gm citric acid on eBay or Amazon [affil links] /1 lit water,immerse object in solution,colouring time up to 4 hours)Hope it helps and good luck!
