Removing lead based solder from copper?
Dear Sir,
I'm writing to ask you how to remove lead based solder from a copper vessel
and replacing it with lead free solder. is there a solvent or acid that can do this without harming copper, brass, or tin in any way?. if not perhaps you can suggest a way that it can be done, and with what tools specifically will I need to carry out the work?
Jonathan Andrew Abraham
hobbyist - Northampton in England
I'd probably start by thoroughly desoldering with a solder sucker and solder wick. Depending on the construction method, this may disassemble the vessel so the remnants can be sanded away.
You can remove it with very fine sandpaper or with scalpel. It can be removed with acid solution too:
330 gm acetic acid on eBay or Amazon [affil link]
50 gm hydrogen peroxide(30%)
1 lit distilled water
