I need to coat copper wire with molybdenum
I want know at to how molybdenum can be coated on copper wire
the copper wire size is 0.45 mm dia. and it shall be wound in spools of 4000 mtrs.
ELECTRONICS. - NASHIK, MAHARASHTRA, INDIA.
Molybdenum disulfide is widely applied to wire as a lubricant, and I'm not sure if this is what you are referring to, or whether you have a reason to want to apply pure molybdenum metal. I don't believe that molybdenum can be electroplate from a conventional aqueous bath, but only from molten salts. Can you describe the application?
Swage Mo tubing onto Cu rod* and draw through successively smaller dies to desired size, with intermediate annealing as necessary. The core-to-total diameter ratio remains constant throughout the wire drawing.
*or preheat Mo tubing or pipe in vacuum, fill with molten Cu & cool.
- Goleta, California
