Cast iron cleaning and filler
I have a cast iron bell needing a thorough cleaning and a few pocks that need filled.
first question is what is the best way to clean?
I have seen sulfuric + phosphoric bath methods.
Question two, what is the recommended putty filler to fill small pockets (only about 1/8" dia. + 1/8" deep)?
I have come across the Devcon 'plastic steel A" being recommended. However, I have also been told it is better to use an epoxy with iron to achieve a filler that expands/contracts the same as the base metal.
would these be the same? is the steel putty just filled with iron?
ANY help would be appreciated. even if it isn't an answer to any of these questions.
Thanks so much.
- New York, New York
You can use 5% ammonium citrate solution (mixture of 50 gm citric acid ⇦ this on eBay or Amazon [affil links] /1 lit water and add some ammonia, pH must be 3,5- citric acid without ammonia ⇦ this on eBay or Amazon [affil links] works too ).As filler you can use mixture of iron dust and some epoxy glue ⇦ this on eBay or Amazon [affil links] .Good luck and hope it helps!
