May I know why boiling test at 4 hour 100 deg C is required? What is the purpose of this test
I would like to why for disk drive components what is the purpose of boiling water test.
Marilyn Soong
It's a poor man's accelerated environmental test. If your parts fail the boiling water test, they will probably fail the required, expensive testing. Doing it will give you a "heads up" on quality issues.
Sheldon Taylor
supply chain electronics
Wake Forest, North Carolina
About/Contact - Privacy Policy - ©1995-2025 finishing.com, Pine Beach, New Jersey, USA - about "affil links"
