-----MIL spec for Powder Coating
Can someone tell me the Mil-Spec Number for Powder Coat? What is the thickness range called out? I have been told .003" to .005".
Mark LangenfeldIteris - Anaheim, California, USA
The Technical Data Sheet(TDS) that comes from the manufacturer with the paint you buy will have an optimal thickness range specified. Coating thickness differs depending on the kind/purpose of paint you are using, mil thickness can run from .05 to 14 mils or higher. If your customer wanted you to produce to a Mil-Spec I'm relatively certain that he would have given it to you.
Sheldon Taylor
supply chain electronics
Wake Forest, North Carolina
