Rusting of stainless steel ISO tanks
I just wonder how we can preserve a stainless steel vessel (type 316) for a long period of time from rusting. also how we can remove rust from the stainless steel vessel (our ISO tanks were rusted from inside).
Hasan Hatug
chemical company - Jordan
Does ISO refer to an ISO manufacturing standard or a chemical in the tank? Was the tank (especially, the welds) initially clean and passivated ? What chemical was in the tank? Concentration? Any chloride-containing impurities? Temperature?
Suggestion: clean and remove rust per ASTM A380 -992005 Standard Practice for Cleaning, Descaling, and Passivation of Stainless Steel Parts, Equipment, and Systems, then passivate using a nitric acid or warm citric acid solution per ASTM A967 -05 Standard Specification for Chemical Passivation Treatments for Stainless Steel Parts.
Ken Vlach [deceased]
- Goleta, California
www.finishing.com is made possible by supporting advertisers ...
