Rust prevention on 1955 refinished metal cabinets
Hello,
I am trying desperately to prevent rusting on the original 1955 steel kitchen cabinets that I have sanded away the baked enamel paint from. They are now a shiny mirror-like finish, but I don't know how ot prevent them from rusting. I tried sprayed on crystal clear enamel, but that only took away the shine and made the cabinets rough instead of smooth. Is there a product that can be coated onto the metal that will retain the original luster and still prevent rust?
Drew Cozart
Homeowner - Falls Church, Virginia
Aerosol high gloss acrylic lacquer should do the job. Follow the instructions on the can carefully.
Try Everbrite [a finishing.com supporting advertiser] coating.
Everbrite worked great. Thank you very much!
Drew Cozart
