Mass microscopic deburring processes for fasteners?
What mass finishing processes are effective at deburring 18-8 (300-series alloy) stainless steel fasteners? Are there any processes that are equivalent to electropolishing, but can be applied to batches of parts (without manual fixturing of individual parts)?
I am interested in processes that will remove microscopic burrs down to approximately 5 microns size or smaller.
The fasteners also require passivation, so please detail if passivation would be required after the deburring process.
Grant Kiehne
manufacturing - Bloomfield, Connecticut, USA
Electropolishing can be done in bulk by the barrel method. This will also passivate the parts.
There are a lot of mass finishing methods and media that can be used to improve surface finishing of your parts; however, there are some that are better than others and most of that has to do with time cycles, quantities, volume and the desired end results. Most non-abrasive burnishing media will achieve bright finishes as will treated dry organic media. Time cycles are drastically different using that same technology system.
tony kenton
AF Kenton
