Titanium oxide coating questions
Q. Dear sir,
I observed a white coating on metal rings (textile components) which I was told was Titanium Oxide. Can you give me the technical details of its process and the properties?
With regards,
C.K.Raveendhran
Metal Finishing - Coimbatore, Tamil Nadu, India
A. Hello C.K.,
titanium dioxide on eBay or Amazon [affil link] is the white pigment that is used in white paint -- it is also used in ceramic glazes. Please tell us what properties you wish to achieve (high wear resistance?). I believe there do exist wear-resistant plasma sprayed titanium dioxide coatings -- perhaps that's what you're thinking of? Thanks, and good luck, but copying something based on a fleeting glance and a third hand report of an ingredient will probably prove difficult :-)
Using titanium oxide for surface activation of components
Q. Why do we use Titanium Oxide in Surface Activation of components for preparing them for Paint?
Ankit Garg
- Gurgaon, Haryana, India
November 8, 2014
A. Hi Ankit. Sorry, I'm not familiar with that. Please tell us how you use the titanium oxide in the surface activation of components, and then maybe I can figure out why :-)
November 2014
