Chroming dissimilar materials
I am building a custom exhaust system where I am considering using the initial section of the stainless steel header pipe from the stock exhaust welded to mild steel for the remainder of the system. I want to have the system chromed but I'm concerned that, due to the different materials, there will be problems with the finish, durability, etc.. Is this a valid concern?
Thanks in advance for any insight.
cycles - Hanover Park, Illinois
Not every plater can do this, but some can. It will be easier for the plater if you use 400 series for the stainless. I think this is what is normally used for the hot sections anyway, as opposed to 300 series - but...why not just make the entire exhaust from stainless and polish/buff it? Will probably cost less than plating, and it will last longer, since the mild steel sections will rust from the inside.
