  Thread 350/50
Plating fused silica fiber
I am trying to EN plate a fused silica fiber. I'm not having much luck. I have plated several other types of glass, but the fused silica is giving me a problem. Any Ideas?
Randy Miler
- Caldwell, Idaho
publicly reply to Randy Miler
What are you doing now and what have you done with those other types of glass you said that worked?
Guillermo Marrufo
Monterrey, NL, Mexico
publicly reply to Guillermo Marrufo
Since ething fused silica in fluoroide solutions may result in a smooth surface instead of a roughened surface, mechanical roughening may be required. Fused silica should take catalysts. I have had success using separate sensitizilng ( stannous chloride 10 g/L with about 20 ml/L HCl, rinse and palladium chloride about 0.1 g/l, and 10 g/L HCl, rinse and 3% HCl dip, rinse and EN plate)
don baudrand
Don Baudrand
(Don is co-author of "Plating on Plastics" [on Amazon or AbeBooks affil links]
           and "Plating ABS Plastics" [on Amazon or eBay or AbeBooks affil links])
publicly reply to Don Baudrand
