Recycling of water with polyglycol ether detergent in it
I need to recycle water that has a polyglycol ether detergent used for washing textiles after the finishing has been done on the metal components. I am currently using the water once and throwing it away. I need to save this environmental resource by recycling. Please help.
Thembinkosi Mhlanga
textile - Mbabane, Hhohho, Swaziland
We were recycled wastewater with oils polluted on ethylene glycol with good results by electrolytic catalytic precipitation (ECP). In 240 minutes the glycols precipitated 27,5 mg/l to 5 mg/l and solids were precipitated in 5-6 minutes. The small sizes of the solids needs 1-3 micron gag filtration but good results. It needs also some catalytic enzymes.
Damian Dinu
- Constanta, Romania
Recycling of water is accomplished in several different ways depending on the amount of water and what's in it, as well as what is required for the water to be re-useable. One common mistake is trying to get the water to a pristine condition before reuse instead of looking at the exact needs and building a process to accomplish that.
You need an expert to look at your application with more detail. Then a recommendation can be made.
Jeff Watson
Jeff Watson
- Pearland, Texas
