Singing The Chemfilm Blues
We have a small lot of auminum castings that we suspect have a Chemfilm problem that prohibits adhesive from sticking to it.
Is there a chemical we could clean these with to correct the Chemfilm issue?
For the short term we are removing the surface finish to expose the aluminum thus allowing a bond. We need a better solution for the long term.
Pete Cappon
calamp corp - Oxnard, California, USA
What you need is a glue that is compatible with the chromate.Talk to the major glue providers.
The adhesive we are using is compatible with chromate because we typically have a very strong bond. Occasionally we have a batch of casts that were not processed correctly causing the fallout. I am looking for a magic chemical that would correct the problem.
Pete Cappone
commercial - Oxnard, California, USA
I would like other responses to this problem. Is the majority of the problem poor house keeping or a step skipped in the process that causes this? The parts look like they were poorly rinsed or rinsed in filthy solution.
Pete Cappone
